Looking for symptoms that could be causing my Gravely mower to leak hydraulic fluid. It is coming from underneath the mower. The 2 pumps, lines and fittings look ok from the top. But when under mower cannot locate leak. Sprayed the under carriage with a garden hose to wash away dirt and oil. Any suggestions where the leak could be coming from would be helpful.
Thanks
Thanks
