Hi. I'm new to the forum so thanks in advance for any help you can provide.
I just bought a Gravely ZT42 with a 23 hp Kawasaki engine. I noticed that while becoming familiar with the controls a pause to long in one area will cause the lawn to burn. It's not noticeable at first but the next day I can see exactly the areas that I paused to long in. And let me add its only takes a few seconds. I notice that the muffler is at the bottom of the engine just below frame level and the cooling air pours down from the engine over the exhaust down to the grass. I have fabricated a heat shield below the muffler which has a back lip a couple of inches high to keep the heat off the hydraulic drive motors also. I now turn off the mower every time I get off to go through a gate or remove a toy from the lawn which can be irritating and I'm not sure if its good to so quickly stop and start a hot engine.
Has anyone else had this problem and what do you do about it? The dealer say normal but it seems like a leaf fire in the fall could be a big problem.
Other than that I like the mower but hate brown spots.
Thanks,
Mike
Thanks,
Mike
