grasshopper 721d
koop1
I need a 721d hydraulic drive motor left hand side.I think the number is 391206 .I have read there are other numbers for this pump.The pump from grasshopper is $1600 there must be another way.Thanks for any help.
nO ITS NOT NEW ITS FROM A 1995 721D with 2000 hrs. I just used it to cut my grass, im going to use the right hydro to fix my 2002 721d. im going to part out the 1995
Re: Grasshopper 721d Firing On Two Cylinders
My mower has been running a bit sluggish lately and is easily bogged down in tall grass. I had it looked at and the mechanic informed me that it was only firing on two cylinders. What could cause this and is there anyway that I can make this repair myself?
