I have a Gravely ZT 2352 home edition. I bought it new and ever since i have had it I have to clean out under the deck before each mowing. Grass builds up under the deck and sticks like glue under there. I have made sure the grass was dry when mowing. My local dealer said it was the blades so I changed the blades then they said it was the bely, changed belt, then they said it wasnt turning enough RPM's. I checked and it is turning almost 1000 more than the specs. Theis has been an ongoing problem for 3 years now and really need a solution. Has anyone else had this problem, and if so did you find a solution? Thanks for any info. It is greatly appreciated.
