stilllearning6
- Aug 22, 2013
- 15
Even after reading the manual regarding the governor spring, I fail to see how to adjust the collar/spring clockwise ( tighter) to increase the RPM.
I can touch the white collar and see the gear teeth on it.
I disconnected the spring several times when I had the carb off.
Now that the carb is back on and the engine is running, I can se that the air vane / spring governor is being overpowered by the flywheel breeze and results in very low RPM .
What steps are required to adjust the collar a few clicks tighter/ more spring tension?
Does the entire carb come off again to do an adjustment?
