govenor problem
woodfar
I have a wood splitter with a Tecumseh 6hp motor. Takes a long time for it to warm up and not chock down when I get into the wood. The governor doesn't seem to be kicking in. Maybe it is the second stage of the pump not working. If I double clutch the valve it will go through the wood fairly well. Any Ideas? Thanks.
