webdeveloper73
- May 18, 2016
- 1
- 1
Ok so my troybilt tb130 was not running right so I took apart the carb and cleaned it throughly the mower then came back to life but being the idiot that I am I decided to just adjust the gov a tad to make it run just a little bit higher RPM well now I can't get it back to the original setting and even tho it runs awesome like it is the throttle plate after running for about 20 seconds gets stuck in the open position and the engine wants to surge when that happens. Any Ideas? thanks in advance So i guess if the throttle plate would not get stuck then the gov is at the perfect setting right now
