GOT A DEAL ON SOME SNAPPERS!
primerbulb120
Picked these up off Craigslist for $25:
The one with the black engine runs great, just needs some minor work. :thumbsup: The one with the white engine would probably run, but it made a loud intermittent screeching sound when I tried to start it. Have to troubleshoot that one. :smile:
I'm going to fix up the mowers and use them. I like them because they're fast. :tongue:
Any comments or things I should know about these mowers?
mechanic mark
Contact Snapper customer support with model & serial numbers & request operators manuals & illustrated parts list only if your interested. By using model xxxxxx, type xxxx, trim xx & code numbers from engines, B&S operators & illustrated parts manuals should be available online. You can google B&S model number plus repair manual & see if it's in PDF form online.
Number Three
Good find. 1974?
I had one like the white engine model back when, and it cut grass with it for 15 years until I moved. I left it there, but the property is still in the family, though I doubt my bro still has that old mower.
