going nuts
jiimyc
i have a 8/32 dynastnar rider and i can not find anyone that can tell me drive belt numbers or sizes i dont want to junk it because it is realy good shap and the motor is only a year old can you help out with belt numbers. any help wood be great. both belts are twisted and streched so cant use them for size
Should be able to help you if you would post the model and serial numbers off the ID tag.
