Hello everyone,
Long time small engine mechanic, having a hair pulling issue with a lawn mower in the shop. It's a dixie chopper silver eagle with a 27 HP kawasaki engine. I'm getting a signal to the starter when I turn the key, but all it does is "click" "click". OK, simple, its the starter solenoid not working, you would think. But, I can run a jumper wire from the battery cable to the small post on the solenoid and it cranks just fine, no problem whatsoever. Test the signal wire to the solenoid and it's getting 12V when you turn the key.
After dicking around with it for awhile, I finally decide to just replace the solenoid anyway, it must just be weak or corroded or something.
Still the same thing. "Click" Click" Touch the solenoid post with a hot wire and it fires right up.
Could I not be getting enough amps to the solenoid? like a bad connection, even though it's getting a 12V signal enough to make it click??
