Got a Generac 0066720. Runs nice and smooth, but the governor is off. It was surging/hunting, and I adjusted the governor per directions I found on youtube. Loosen nut on governor arm, open throttle to full, gov arm fully in that direction, rotate gov shaft cw. It didn't move much, but now as soon as I take the choke off, it hits full throttle. I can throttle back manually and it runs fine, but the gov just goes to the wall. I'm new to adjusting governor, so I'm sure I did something wrong. This is the video I was going from. I tried adjusting the spring on the gov arm, but I loosened it till it's hanging, and still goes to full throttle.
