rpriester
- Sep 5, 2020
- 1
- 3
I am having trouble with my Craftsman LT2000 Lawn Tractor. It has a cvt transaxle with just forward and reverse, not hydrostatic. It started off with jerking when going up and down hills. It’s like it can’t handle the weight of the tractor and the gears will strip and then catch. I am still having that problem, but I am also having problems now with the gears grinding in reverse. It just sits and grinds in reverse. Do you think the shift linkage need adjusted? How do you adjust the linkage? Or, do you think it could be something worse? worse?
