Manufactured in 1982, I have a service manual which dictates use sae 90 wt OR sae 140 wt gear oil. Manual also says don't use multi-viscosity oils. I've yet to find straight 90 or 140 wt gear oil.
I've found tons of 85-140 wt heavy duty gear oil. I'm thinking that with the progress in oils since the manual was printed that this Multi Viscosity HEavy Duty Gear Oil made by Lucas would be safe to use in this tiller.
I need second opinions or advice on this.
Thanks Much
Thanks Much
