Fatdaddy
Z326 When light comes on and blinks for my rt tank if I switch tank and fill up that tank only holds a little over 3 gal. Its a 5 gallon tank is that right. I now do not fill up until the light quits blinking then it holds about 3.7 gallons.
Is there a trick to getting more tank time something I can do... If a tank runs out can you must switch over the the
other tank ? Do you have to bleed it or what? Will it fire right up?
