I have a Briggs and Stratton 21HP V engine. Cleaned carburettor replaced seals, checked float and needle, checked fuel cut off solenoid (it works). Checked compression and found 175 lb/sq" both cylinders. Engine runs smoothly with lots of power. I am totally baffled as to how the gas gets in while I am running. Does not get in when not running. Appreciate any ideas.
