My Honda lawnmower was working fine, but when I went to get a couple sparkplugs and other things, a long time employee told me I should switch to a mid-grade gas and he recommended additive called Mile-Hi RTU it is $15.95 for 1 pint...is this necessary? You use 2oz per 2 gal
Rather than an additive, just follow these steps:
--At the end of the mowing season, run the mower until it runs out of fuel, or drain all the fuel from the tank.
--After the engine stops, loosen the drain screw on the bottom of the carburetor and let the last bit of fuel drain out.
--Dump any leftover fuel in your fuel can into your car/truck tank---don't store gasoline over the winter.
The worst thing you can do is allow fuel to sit more than 30 days. Modern fuels, even mid-grades, will decay and slime/gunk will form, often clogging up the inside of the carburetor. Some fuel stabilizers or additives can delay this, but they don't always work. Better to simply get the fuel out of the mower and be sure not to have any problems in the spring.
