1dcforrest
- Mar 10, 2021
- 1
- 4
I have a 2015 G5500 Garden Tractor (917.204030) that has an interesting problem...
Long story short, attempted to start it up with a recharged battery, drained the batt while trying to get new gas into/through the engine from being stored over the winter and blew the 20amp fuse.
Bought a new battery and fuse, and now all the system does is light up the electronic ignition switch (seems to work properly), but when I attempt to start it, all I hear is a quiet click near the air filter inside the engine. Thought I may have damaged the starter solenoid, so I replaced that too, but it still only does the same quiet click within the engine when trying to start.
No solenoid 'loud' click, no turnover. Seems as though all the safety components (brake on, PTO down) are functioning. One odd thing is I can 'try to start it' whether I'm sitting in the seat or not...i.e. all I get is that quiet click, in the seat or out of it.
Would blowing the fuse cause something else to be damaged?
