G2 Transmission Tube assembly question
rwasiniak
Hello,
My 928D G2 appears to be leaking from the top of the Tube Assembly that connects into the Hydro Pump.
I was able to loosen the top nut that attaches the Tube Assembly to the Hydro Pump. The issue now is that due to the Tube Assembly being metal, I need to do the same to the other end that connects to the Wheel Motor to remove it and possibly replace.. How does one do that? There isn't any room to move the 1 1/4" wrench needed to fit that nut holding the Tube Assembly to the wheel motor. What is the official method to do this?
