G2 Trans issue
rwasiniak
Hello,
I have a 1999 928D, and lost movement on left side. Found there is Transmission Oil leaking from the Tube Assembly that connects to the top of the Hydro Pump.
First order is the get the mower to be able to be pulled back to garage. I'm reading that there are dump screws on the side of transmission. Does someone have a picture of where these are located? Can't find anything online showing these.
For the leak, would this be replacement for the Adapter fitting or might I need a new Tube Assembly?
Thanks for any help anyone can provide.
Rob
Hmmm if my info is correct you Hydro Gear 21L pumps or at least that what the G2 service manual indicates. But I also seeing what appears to be an Eaton transaxle used. on some the 928D mowers. So I am a little lost here but basing the info on you saying you have G2 system.
Pay attention as one you are loosening. If I remember correctly the hex is a 5/8 wrench size.
