B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Aug 1, 2026 #11 Does it matter if the split flex line is below the oil drain hose ? I read somewhere it should be above it. Attachments IMG_1596.png 4.4 MB · Views: 6
S slomo Lawn Pro Community Leader Joined Jul 14, 2019 Messages 7,197 Aug 6, 2026 #12 If it was mine, I would remove the drain hose and put a plug in it. MY LUCK, all the bouncing around mowing that hose would come off and lose all the oil. Back to your question. I would route the hose draining end above the engine block oil port.
