Fuze blowing
joebaehr
20A fuze in ignition ckt, repeatedly blowing on Husqvarna LGT2554 tractor
mechanic mark
http://www.husqvarna.com/ddoc/HUSO/HUSO2012_NAen/HUSO2012_NAen_LGT2554_532432908R5.pdf Hands on, inspect wiring harness, all switches, relays, unplug one by one, inspect contacts if o.k. re-plug one by one, look for bare wires, burn spots, make sure everything electrical is tight and secure including ground cables & straps. Test starter solenoid:
https://www.google.com/webhp?source...how to check starter solenoid on lawn tractor
https://www.google.com/webhp?source...spv=2&ie=UTF-8#q=fuse blowing on lawn tractor
