I have a 2013 Ltx 1042 KW with a blown fuse. Where is the fuse located?
E echo210 Forum Newbie Joined Jun 3, 2012 Threads 1 Messages 1 May 1, 2014 / Fuse #1 I have a 2013 Ltx 1042 KW with a blown fuse. Where is the fuse located?
M Mikel1 Well-Known Member Joined Jul 21, 2013 Threads 10 Messages 897 May 1, 2014 / Fuse #2 It is between the solenoid and ignition switch. There should be a red/white wire coming from ignition switch, follow it or trace the small red wire from solenoid and follow it. It has a 20amp fuse.
