Fuel Solenoid 721D
dawglloyd
Where Does the black wire hook to on the starter that comes from the fuel solenoid.
Wiring Diagram just shows it at the starter.
grasshopper 721D 91
Thanks
Are you sure that the diagram shows it going to the starter? Most of the time the fuel solenoid is connected to the run circuit off the key switch.
