Fuel problems with JD LX 279 Mower
DJDon
Have rebuilt carburetor, have new spark plugs to install but want to replace the fuel lines before starting up again. Also want to clean out the fuel tank but it seems to be quite a job to remove the tank and i am wondering if there is a way to clean the tank and line from the tank to the filter without removing the tank. If removing the tank is necessary, then can i get some expert instruction on the process on the LX 279. ANy and all info will be greatly appreciated!
.Thanks,
DJDon
