Fuel pressure prime at start up
Jamesd62
I have a 1991 EFI 26 hp walker that has stopped pressurising the fuel system at start. Runs fine once it starts. Trying to figure out what controls the fuel pump to pressure the system at start up. Thanks in advance
Auto Doc's
Hello J.,
We need the product label information off the machine along with the engine product label information.
hlw49
Try turning the ignition on and off. Some you have to cycle the ign on and off and some the pump runs until it builds pressure.
FixItFrank
Had a similar headache with an old mower of mine. I'd bet it's your fuel pump relay. That's the little switch that tells the pump to run for a couple of seconds when you turn the key. It's probably just worn out from age. Easy way to check is to find the relay (usually in the fuse box), and when you turn the key to the 'ON' position (don't start it), you should feel or hear a little 'click' from it. If it's silent, that's likely your problem. You could also check the fuel pump fuse while you're in there.
Just an idea. Let us know what you find with more photos. Gook luck!
