outsider347
Hello
new guy here with a yerf dog go kart. Hoping that you folks can help with my problem
My Tecumseh OHH 60 71131C is misting fuel out of the carb when I hit the accelerator. Engine hesitates a moment, then seems to increase rpm ok. If I go to about mid throttle & snap it to wide open it will mist fuel out again
Adjusted the valves .004 on both - cold
The engine starts fine ( several primer bulb pumps)
and idles great after warm up
I put a new after market carb on because the oem carb was doing the same thing...probably nothing wrong with the orig carb
Have not opened up the motor yet
Thanks in advance
Thanks in advance
