i have a 1976 lawn boy 7265 with d601 engine ..went out to garage this morning smelled gas .carb is leaking on bottom where the little spring /screw is located.whats up guys any ideas .i
You're welcome. You won't have to remove the carb if you have a right angle phillips, or a very short one. Be careful tightening the four screws back. That plastic carb body is easy to strip. I've done it.
