fuel issue?
Scott d
2005 Dixie Chopper XWF2700 kOHLER PS-CV740 Unit runs a dies. Sometimes 5 seconds, sometimes 2 minutes. Sound like it is running out of fuel. Changed fuel filter and have good flow from tanks thru filter. Installed new fuel pump. still have problem. It does pump from the fuel pump when cranking.Do you think it might be the carb solenoid? I have 13.5 volts to it while running. I can disconnect it when it id=s running and it sounds the same as when it dies on its on. Some times will run and stutter and run and stutter before dieing. Suggestions? Thanks
