Auto Doc's
- Sep 7, 2024
- 1
- 52
Many of you run across this, so I am pointing out the issue for mainly visitors and the novice DIY types out there.
If the engine crankcase is flooded full of fuel, it seldom means the carburetor is the problem. Most modern small engines especially those used on rider mowers have a pulse operated fuel pump. The diaphragms fail in these pumps and the fuel is leaked into the crankcase through the pulse line that often connects to a valve cover or the crankcase itself.
For models with a mechanical fuel pump on the side of the engine it can also happen to them but not as frequent. Drain the oil/fuel mix out and then the pump can be loosened up, fill the fuel tank and watch for fuel weeping out of the pump itself where it bolts to the engine.
Of course, engine with nothing but gravity feed fuel to the carburetor, the float and needle are the likely suspect for this problem
