LakesideBon
- May 9, 2013
- 1
- 1
My mower quit running. The fuel pump wasn't running when the key was on. I Pulled the fuel hose and no fuel was coming out of the filter. I waited for about an hour and then the pump ran when the key was turned on. I started mowing and after 15 or 20 minutes it did the same thing. I let it sit and then it started.
I changed the 2 fuel filters and ran the mower for a couple of hours with no problems. Next day had the same issue. I do not understand why the fuel pump stops running and then after sitting for a while it starts again. Actually it starts after I remove the fuel line and then turn the key on. Thought maybe the fuel tank cap vents might be plugged and causing a vacuum, but ran the mower with the fuel caps loose and had the same problem. Maybe it is a bad fuel pump bit comes back on after sitting.Any thoughts or suggestions.
