458italias
- Mar 31, 2013
- 1
- 3
The exmark navigator is $15,000 new! Homeowner selling:
Exmark Navigator with 20 hp kohler motor with 116 hours. Brand New Blades and completely tuned up, all fluids, filters, new battery lubed and ready to go. Needs nothing.
2013 Exmark Navigator - YouTube
There's Mowing. There's Manicuring. And then there's Navigating. Nothing is perfect. But a lawn maintained with an Exmark Navigator may be as close as it gets. That's thanks, in large part, to its patented adjustable flow control baffles. Combined with a larger-diameter blower, the Navigator generates more air flow for better vacuuming and debris collection. And this year's model is perfectly suited for any pro who wants even more controllability, responsiveness and less hand force. Another Navigator signature trait is the higher blade tip speed for slicing grass into finer particles. Then, its rear-discharge deck designed with two-sided trimming lets the operator accurately control discharge, keeping flower beds and walkways clipping-free. And the Navigator does all this at speeds up to seven mph. So, you can Navigate a virtually perfect lawn in no time.
Located in willoughby hills ohio zip code 44094
440-306-2623 - leave message
