I have a honda harmony II model HRZ216 TDA with front wheel casters. The cable that pulls the pin out of caster so the wheel can spin around 360 does not disengage far enough out of the locking position. I have taken the caster assembly and the lever assembly apart looking for a cable adjustment but have not been successful. Can anyone help me? Do I need a new cable? Can I cut 1/2" off the end of the cable?
Thank you
Thank you
