Front Weights?
SmokinAl
I just removed the powered bagging system from my Gravely ZTX42 and installed the mulching kit. Should I remove the weights from the front of the mower or does it matter? The weights came with the bagging system to counter the weight of the bags on the back.
Thank you
Auto Doc's
If you are going to switch back later, I would leave them in place.
hlw49
Should not matter and may help keep the front caster wheels on the ground on steep hills. If you have hills.
