front right tire tearing up lawn
Shagbark
Simplicity prestige w/power steering 50in deck, hydro, tears up yard when I make left turns around trees.....so its actually the right tire. I checked the tire pressure, bearings & verified the rim was not bent, its as though I needed a front end alignment.
BlazNT
Check to see if both tires point in the same direction after you park it. You can do a front end alignment on them.
gmash1
What did you ever find out on this? I am concerned with mine. I think the power stearing may be set incorrectly. It will turn sharper to the right than the left. There is a fixed stop on the left tire but not on the right. Anyone have any experience on setting up the power stearing on these?
