the engine cuts off when 2-3 gallons have been used out of a full tank and choke is required to keep engine running with the blades disengaged
after 3-4 minutes the blades can be reengaged and resume cutting grass for approxiamtly 5 minutes then the problem occures again. I have cleaned gas lines and checked the pick up in tank. As long as tank is full,there is no problems. It has to run about 1-1.5 hrs ,then the problem starts. any solutions or info on this problem would help. Thanks Lewis in SC .
