I was given a murry 40" 12.5 hp garden tractor. It is one of those "you get it running, you can have it". I am afraid that the motor is locked up. Is there any way to tell if this is true? I took the belt off of the deck and tried to turn the pulley connected to the motor shaft but it wouldn't budge. Someone told me that with it being a high compression motor, I would not be able to turn the motor that way.
tractor info: model 40702x92f
mfg date/serial: 953003-053080
engine info: 12.5 hp
model 289707
type 0121 01
code 9412204A
any help or advice would be great.
model 289707
type 0121 01
code 9412204A
