I have a Kawasaki FR651V 22 hp engine on a Cub Cadet zero turn that I noticed was leaking oil on the rear side dripping down on the muffler and puddling on the floor. When I went to crank it after it sat in the garage for the winter I noticed the leak. I’ve never seen this engine leaking oil before.I haven’t been able to identify where it’s coming from. Does anyone know of weak or typical areas where this engine is known to leak oil? It is dry around the oil filter and oil drain tube. Thanks, David K
