Ford LGT 145
618connelly
Have a Ford LGT 145 with open sides. It was a bad winter in Pa. so I decided to clean it up. Hydraulics for mower deck leaked. Had the cylinder and the control valve rebuilt. Finally got it all back together and the deck won't go up and down. I noticed a screw on the back of the control valve. Could this screw be causing the up and down handle for the mower deck to be locked up? As i recall the handle used to have a lot of movement for up and down. Now the handle movement is very limited and stays in the up position.
Thanks in advance for any help!
618connelly
