Flywheel screen question
mn.mike
I wore through the front wheel of my 8243AE (1987) and committed to buying a group of parts to refresh everything that was damaged.
The flywheel screen was damaged and I removed it a couple years ago.
When I looked at the parts diagram, there are two versions.
1) Screen F'wheel S 611375
2) Screen F'wheel PL 610745
There isn't any guidance at LawnBoys site to explain what S and PL mean. I looked around the internet and found a picture of one, but there was a piece of paper over the center, and a lot of the other pictures always had a hole in the center. I remember mine as fully closed, as it is electric start.
I looked in the obvious boxes where I would have saved the broken part, but things hide after you move to a new home.
Does anyone understand what S and PL mean?
I was also in the market for a new Control Cable 682685, and noticed the picture on many websites had a "STENs" watermark. Are these third party replacements as good as the OEM parts?
Thanks, Mike
mn.mike
It is all back together and back in action. The correct PN for the flywheel screen was Screen F'wheel S 611375.
Rudedog
How did you end up figuring it out?
