Post complete model number, thanks. A roll pin from hardware store should work, take part with you for proper fit, a small hammer & punch will be needed to install roll pin.
Mower details are:Craftsman Mower with Briggs & Stratton Gold OHV 140cc engine
Mower model (Craftsman #) is 247.370100
Briggs & Stratton Engine Model is 90P702 0007 F1
The float pin is not held by eyes, but an open circular slot. I fear that a roller pin would merely expand the plastic part until that pin also loosened. I was thinking about using some thin stainless steel or other non-corrosive wire to lock the pin in place. I would likely need to file an indentation in the pin for the wire to hold and to also drill a very small hole (1/32" or less) to insert the wire. Any thoughts? Many thanks for great ideas.
