Float Bowl Gaskets
1948man
I'm looking for a float bowl gasket for a Kohler KT 730 3046. The carb, I believe, is a Walbro 16-853-19s. Is there a way to find these? Mostly what I'm seeing are full kits and the few that are gaskets only use a part number I can't find for Walbro. I have the number for the carb but not for individual carb parts. The OD should be 2" or maybe 2 1/16". Are Briggs or Tecumseh bowl gaskets about 2" likely to work?
25 757 28-S kit
