<1 acre...~5% slope...have a wet soggy yard sometimes so i think the larger tires of a tractor may be better than a zero turn...any advice would be appreciated...thanks in advance
wants/needs
-needs to have an easily removable bagger
-needs to be able to mow in reverse
-would like the ability to tow a thatcher, sweeper, spreader, roller and garden trailer
-would like the transmission to be able to handle towing rocks in the garden trailer
-needs 42"-48" fab deck...for maneuverability around obstacles in yard and a better cut with some uneven ground...mower + bagger attached have to fit through a 6' wide shed door
-would like to be able to easily remove the deck
-needs hydrostatic drive
-kawasaki or other 20+hp reliable engine
-easy oil changes
-reliable
looking at the following Husqvarna models at the moment...open to other brands though...not too sure how many quality brands there are out there...john deere and kubota are nice but a little too pricey but i would buy a low hour used model if it fit my needs...
TS348XD
https://www.husqvarna.com/us/products/riding-lawn-mowers/ts-348xd/960430242/
YT42DXLS
https://www.husqvarna.com/us/products/riding-lawn-mowers/yt42dxls/960430220/
YT48DXLS
https://www.husqvarna.com/us/products/riding-lawn-mowers/yt48dxls/960430226/
is there a model GT48DXLS?...doesn't show on their website
was researching zero turns in the thread below...just trying to get more info to make a choice...
http://www.lawnmowerforum.com/showthread.php/46823-First-Zero-Turn-Looking-at-Toro-Exmark
I have a Husqvarna YTH24V48 that has been great. I don't know about a bagger attachment, as I just use a mulching plate, but it mows great, and mulches leaves and grass nicely. Lowe's sells them for under $2000, and so far, I would have to recommend this brand. The deck is "stamped", but has reinforcing plates, and I have "rubbed" dozens of my trees, with no damage to the deck. I mow about 1.5 acres, and it handles the slopes nicely. The "reverse" mowing works great, and oil changes, etc, are easy.
Out of all posted the only one that will do what you have listed for needs is HUSQVARNA TS 348XD
Not cheap but the John Deere x304 (FWS - Four Wheel Steer) will turn leaving an uncut radius of 16". I have an older, no longer available, John Deere SST18 ("O" radius turn) and it is great. But if I bought a new one, I would buy either the x304 with the 42 inch deck and the 16 turning radius or the x324 with the 48 inch deck and a 9" turning radius.
I have over the past 30 years used on a regular basis an Ariens (riding mower) 5 years, a Wheel Horse Garden Tractor 14 years, A Cub Cadet Lawn Tractor 8 years (it is now my spare) and the John Deere SST18 for the past 3 years. I prefer the John Deere.
Good Luck,
The 4WS JD's are in a class above the Husky's you list. They're probably at least double the cost of the Husky but this is one of those cases where you actually do get what you pay for.
I don't own a 4WS JD but two of my neighbors do. I don't know exactly when they got them, but we've been living here for 15 years and I've never seen either of them have any trouble.
Does that JD have the horizontal shaft Kawasaki V-twin and 4WS? If 'yes' to both, that's a plus but at a $6k original price, I doubt it does.
Another thing to consider is, private sale = no sales tax. Tack that onto the price of the new Husky.
JD originally sold for almost twice the price of the Husky. With only 180 hours on the clock, it SHOULD have a lot of life left in it.
