Tedfixedit
Just out of the blue won't crank shut it off to add fuel. Acting just like a safety switch is not engaged. Checked all switched, tested ignition switch, all good. So I figured it was a relay issue so I tried two new ones and this was not this issue either. I pulled the relays and jumpered the yellow wire that supplies the starter solenoid so I could finish the lawn but hate running it without any protection. Any thoughts? Module Time Delay
