Thank you!Can you unplug the PTO wires, and the blades still stay engaged? If so, it likely has a seized-up/ failed PTO bearing.
AD, You mean a PTO seized/stuck in the on position.Can you unplug the PTO wires, and the blades still stay engaged? If so, it likely has a seized-up/ failed PTO bearing.
YesYou mean a PTO seized/stuck in the on position.
Hello G.,AD, You mean a PTO seized/stuck in the on position.
So I found out I had a stuck bearing I fixed that now I cant get the blades to engage I checked the fuses what should I look for now?2017 Ferris srs z2 61" 28hp vanguard blades won't disengage. I've tried a new pto switch and that didn't fix the issue. I'm just looking for any input on what i could try to fix the problem. Thank you!
I dont believe the gaps adjustable I tried the wires going to the clutch and theres nothing there so I guess im going to trace wires or change the control moduleHello L.,
If you have a multimeter, Ohm the 2-pins going to the clutch with it disconnected from the chassis harness.
If you don't get a resistance reading, the magnet windings are likely burnt.
Is the air gap adjustable on that clutch design?
