Hello,
Thanks for any help available. My hydraulic belt came off so I turned the 2 hydraulic release values 2 turns as the manual states to do. After pushing it to the garage I replaced the belt and tightened the release values back to the original position.
I have hydraulics on the right but only a slight amount of movement on the left. I attempted to tighten the value a tiny amount and now it turns freely like it is stripped out. It looks like it may have been originally cross threaded when built? Either way I only have movement on the right hydraulics. ANY SUGGESTIONS?
Thanks
Thanks
