Ferris IS4000z fuse location
Robert Sharp
I am new to this forum. I have a Ferris IS4000Z since 1994 and never had any problems. Always performed regular maintenance. It has 699 hours. Last week a clutch belt and drive belt failed so I replaced all 4 of them. Since then the engine will not start. I have power to the Fuel pump at the start switch but not at the pump. I need to check the fuses but I can't locate them. I thought they may be under the left instrument but nooo. Any suggestions?
