Blades Ferris IS2100 best blade for St Augustine Grass
draidt
I have a newly purchased Ferris IS 2100 52 " cut and had a mulching kit installed along with a Quik Chute, I am not happy with the quality of cut either mulching or discharging. My 9-year-old Hustler Mini Z does a better job. Can someone recommend a set of blades that does a better job ? I am cutting St. Augustine.
Maybe try the high lift blades. I do not think mulching blade lift very well. I use my G6 blades when the grass has lots of junk in it so I do not pick up as much.
I agree! G6 blades are the way to go. Contractor Supply Club sells them starting as low as $9/blade.
