Ferris IS2000Z will not start
ColtLyles
I was cutting my grass today and stopped, I shut it down. Came back moments later and it would not turn over at all.
All safety switches were engaged. (parking brake, arms out, blades off)
Any suggestions on what the problem might be? It has appx 700 hours on it.
Rokon
Will it turn over manually?
Battery? Voltage, load test?
Ggrip
I've got the same problem Was running /mowing fine Shut off blades, could'nt re-engage. Shut off mower. Went to restart and nothing but relay clicks. All safety switches functioning. Tried new ignition switch, same problem. Fuses good but no power to PTO circuit. Any ideas?
Rokon
There is an open circuit on both your mowers.
Of course this is internet diagnosis at it's worst. :tongue:
