Kawasaki FE290 idling after rebuild, runs smooth n' sweet.
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 266 Messages 6,632 Dec 12, 2018 / FE290 Rebuild #1 Kawasaki FE290 idling after rebuild, runs smooth n' sweet.
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 266 Messages 6,632 Dec 27, 2018 / FE290 Rebuild #2 Im running Motul 10w40 break in oil. When should I change it? It's in a Mule so it will be used a little every day.
Scrubcadet10 Moderator Staff member Joined Sep 24, 2017 Threads 266 Messages 6,632 Jan 29, 2019 / FE290 Rebuild #3 I'm about to do then 10hr oil change as says in the manual, I'm wondering if I should use Kawasaki oil, or shell, valvoline etc...??
