Fd 590v liquid cooled 18hp
Andy C.
I have kaw fd590v . Had a leak valve cover gasket ended up breaking bolt off in head, Took head off To get broke bolt out. Should have I took head off without adjusting flywheel, or will it be ok to put back on the way it is? Thanks
Craftsman Garage
yes you absolutely don't want to ever adjust the flywheel on one of those engines
Andy C.
I’m new to this project. Part of my question was probably stupid to say. Just don’t want to screw this up putting it back together. Thanks
Scrubcadet10
Moderator
Staff member
What did you mean by adjusting the flywheel?
Scrubcadet10
Moderator
Staff member
If you just removed the cylinder head. No it isn't.
You do want to readjust the valve clearances as they may changed. To me I always loosen them taking a head off so it is automatic here to readjust.
